F2 turn signal problem, I NEED HELP!!!!
Old Apr 6, 2010 | 09:02 PM
RoosterF3's Avatar
its confirmed that there is only one wire running to the relay...... what 3 wires are those? i have a diagram but its confusing as to which relay is which. This is beginning to be a pain.
Old Apr 6, 2010 | 09:14 PM
RoosterF3's Avatar
ALso i did just find out the two front turn signal harnesses are intact on the fairing stay but i need the wires that run to the sockets for the bulbs in the built in signals dont i?
Old Apr 7, 2010 | 09:19 AM
cristopech12's Avatar
yeah you are right, you need install the wire and plug in the harnesses. how many wires have each harness?. if you have 3 you need to get the original flash relay, but if you have 2 wires maybe you can install a car flash relay (i do that). but in my case i don't had the wire system, i make a new one.
Try to find it on ebay, and if you have only 1 wire on flasher relay you need install the other two.
You have 3 wires (Gray - Black/Brown - Green):
You need check and install(if you don't have it) the Black/Brown wire from the fuse box until the flash relay (this wire is the power), then you need install the gray wire from flash relay and follow until the turn signal switch,the other green wire is for ground. but i don't know the order, but if you have the harness you can see the correct order.
cheers
Cris
Old Apr 9, 2010 | 09:41 PM
RoosterF3's Avatar
okay so coming out of the relay i have 3 wires, a green, gray and blue brown, the only wire still attached is the blue/brown. Where do i need the other 2 wires to run?
Old Apr 10, 2010 | 09:26 AM
Ok, in this picture appear those wire that we are talking about.
1.- the Black/brown(or blue/brown) if you follow the wire, goes from the fuse box and finish at flash relay.
2.- the gray wire. you must check first on the turn signal selector (left clip behind and below the clutch lever) the wire group controls the low beam- high beam, turn signals, horn, and "optic horn", in that wire group you must find the gray wire and follow until you get the cut part, when you find it weld it with the other gray wire part on flasher relay.
3.- the green wire you can add it on another green wire. it's for ground.
If you are gonna use the OEM flasher relay, connect this 3 wires, because you can use a car flasher with 2 pins and you only need to connect the blue/brown and the gray wire.
Cris
Fallen3
Sep 28, 2010 03:56 PM
utter05
Jan 22, 2009 01:10 PM
Stugots
May 1, 2008 03:51 AM
dewthedoo05
Sep 4, 2007 09:32 PM
gotcharr
Mar 3, 2006 11:48 PM
