F4i gauge swap gone wrong....
Old Apr 10, 2010 | 12:21 PM
willo's Avatar
Default F4i gauge swap gone wrong....
I spent some time working over the harness on my F4i gauges using forum info. Some things didn't match up so I pulled up some wiring diagrams and sorted it out.
Then I screwed up.
I needed an ignition+ line to activate the gauges. On the F2 diagram, there's an ignition+ source that feeds the oil sensor indicator.
It turns out that that line ALSO gets grounded when the ignition is off.
I now have a lovely new $130 paperweight for my office. Maybe I'll turn the tach into a clock or something.
Grrrr.
Old Apr 10, 2010 | 03:34 PM
willo's Avatar
Default Hah! I sorted it out
After putting the gauges on my bench for a while, I pulled out my bench power supply and played around a bit. It turns out that there are two ground lines in the F4i gauges. A green and a green/black wire. One takes care of the illumination ground and the other handles all of the gauges/indicators except for the brights indicator, which is on the first ground plane.
I didn't have green/black grounded, which made the display only come slightly to life and convinced me that the gauges were fried.
Now they're wired up and I just need to spend some time building a speedo sensor.
Old Apr 11, 2010 | 11:29 AM
CrashTECH's Avatar
Please share your results! This would be awesome!
danl23880
Oct 28, 2010 12:47 PM
delaystomper
Oct 4, 2010 10:23 PM
zebrabullet
May 6, 2009 07:03 PM
Armstrong
Jun 8, 2006 08:31 PM
