Detailing Discuss detailing your ride within.
How to Repair Scratch Gas Tank?
Old Aug 6, 2006 | 10:33 PM
Cypress_CBR's Avatar
Default How to Repair Scratch Gas Tank?
I have one deep scratch on the fuel tank of my '04 CBR1000RR (Honda calls it the "top shelter").
Has anyone ever repaired deep scratches on this cover, or is there a professional service that can blend the scratch? It is below the color layer.
Thanks!
Old Aug 6, 2006 | 11:24 PM
Demon RR's Avatar
Default RE: How to Repair Scratch Gas Tank?
if the scratch is to the base coat, then repainting is needed. wheeling out/buffing the scratch will do nothing cause its too deep. UNLESS the scratch is really thin, then wheeling out/buffing might work. using touch-up paint will only make it worse. it will look like a scar on top of the paint. then you need to wet sand smooth and buff out.
i deal with this everyday at work. if you can, throw up a detailed pic of the scratch. also, if you take a pic, place a coin or something for a size reference next to the scratch. i might be able to tell what would be the best method for fixing this.
dave
Old Aug 7, 2006 | 12:00 AM
Thanks for your opinion. You are 100% correct ... the scratch is to the base coat, and is about 1/8 inch wide X 2 inches long. Probably about 1/64th deep, likely less.
I will try to post a photo later this week, but I agree, a repaint is likely in order. Or, buy a new tank cover from Honda for about $300.
Marc
Spadez
Jan 8, 2013 01:42 AM
bluej511
How-To: Mechanical
21
Apr 10, 2008 10:55 AM
Flogger
Feb 15, 2008 03:52 PM
photo2u
Aug 6, 2007 11:03 AM
Cellesaurus5
May 4, 2007 08:34 PM
