How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
DIY scratch/scuff repair.
Old Mar 6, 2008 | 12:28 PM
bluej511's Avatar
Default DIY scratch/scuff repair.
Alright first off i am not responsible for you screwing up your fairings this is just a DIY.
Tools needed:
Touch up paint/pen.
Sand paper (must be wet sanding compatible) 2000-3000 grit.
Rotary/orbital with polish REMOVING (not hiding) capabilities for 2000-3000 grit sand marks.
Now i don't know if OEM fairings have a clear coat but i'm sure they do if anyone can comfirm it would be great. Don't try this if there is no clear coat.
Now the first step is to touch up the area thats scratched. You can get a bit to the surrounding area thats ok. Now make sure the paint is above the clear or level. Its easy to tell if the scratch is not visible anymore then you've gone above the clear which is good.
Here is a picture of what it should look like with the paint all dried up (24hr cure time is preferable)
You can see that its a bit past the scratch and you can see a couple more areas on the right i touched up.
Now take your sand paper and leave it in a bowl of water for a couple mins then start wet sanding only the area that you painted. If you make an area too big its ok (this is why its important theres clear coat. Scuffing up clear coat is ok) Let the sand paper do the work, take your time and once the color looks blended in you can stop. As you see in the picture you can't tell between touch up and original.
Now after this wipe it down with a clean MF (microfiber rag) make sure all the water and elements are gone. Now take your buffer or orbital and follow the instructions on your polish. I used Optimum Polish because it does not fill in but actually remove.
There is the final result and as you can see i circled whats visible of the damage. Now i had to hold this under the light and at an angle to even catch a glimpse of it.
Here is another scratch i caught and fixed
Before
After
Any questions feel free to ask. Once again i am not responsible for damages and this will more then likely not work if trying to buff it out by hand.
Old Mar 8, 2008 | 01:16 PM
bluej511's Avatar
Default RE: DIY scratch/scuff repair.
Wow nothing huh
Old Mar 8, 2008 | 01:50 PM
Onarom's Avatar
That is very impressive. I have a few scratches I will try this on. Thanks for the post!
Old Mar 13, 2008 | 05:48 PM
bluej511's Avatar
Anyone else have any comments/questions/ideas haha
Old Mar 20, 2008 | 10:07 AM
WoodyRR's Avatar
This seems awfully nice...do you think it's worth a try on these parts? (Tail scratch on crease, silver part of the upper and very small part on top of lower)
[IMG]local://upfiles/16333/B564E4EE37104D58ACAC179B6A1D2BF2.jpg[/IMG]
[IMG]local://upfiles/16333/7E330A76A31A404CAFBB42292995D56A.jpg[/IMG]
[IMG]local://upfiles/16333/25BB54C467584A7DBCBEBBF68253CAAF.jpg[/IMG]
[IMG]local://upfiles/16333/5B737E6014F846218CF58BA5F6E4AE69.jpg[/IMG]
Old Mar 20, 2008 | 11:37 AM
bluej511's Avatar
Corners really suck to do cuz its hard to buff. If theres a clearcoat on the paint id def try it its worth a shot. Make sure when you paint it its even or above the surrounding paint. Do thin layers give it a bit to dry and do it again. Then wetsand and buff. Post some pics up if it works out.
Old Mar 21, 2008 | 08:19 PM
WoodyRR's Avatar
Will do. Thanks for the confidence boost.I'll def post some "after" pics if I do it...have to find an orbital first.
Old Mar 21, 2008 | 08:32 PM
bluej511's Avatar
Even if these is no clearcoat you should be ok, the finer the sandpaper the better. You can buff paint without a clearcoat it just goes all over the pads you use. If you use an orbital might take a bit longer to remove the sanding marks. I recomend a porter cable. Maybe someone near you knows how to detail and will let you borrow one. Make sure you get a polish that removes sanding marks and doesnt just fill em in ie scratch x, most meguiars over the counter.
Something you can buy at the store is megs #83 or 89 i dont remember it removes scuffs.
Old Mar 22, 2008 | 09:12 PM
WoodyRR's Avatar
I figured I'll buy some 2000-3000 grit paper like you suggested in the post. I was trying to find some polish with "removing" capabilities, but didn't see that description in anything online...I'll just have to go to a store and read the bottles. However,I went to "Meguiar's" website and found this under "motorcycle care" :
http://www.meguiars.com/?/Motorcycle...d-Wax-Wet-Look
Do you think that'll be fine?
Old Mar 23, 2008 | 09:16 AM
bluej511's Avatar
Here woody try and find some of these. You can always order from autogeek.net
