Help! Keeps blowing speedo fuses!
Old Nov 29, 2007 | 12:48 AM
fstR1's Avatar
Default Help! Keeps blowing speedo fuses!
Got a 2001 929rr.....as soon as i turn the key on, the 10A fuse blows for the meter assy. What would cause that?
Old Nov 29, 2007 | 01:24 AM
demonchild's Avatar
Default RE: Help! Keeps blowing speedo fuses!
a power grounding out or two wires touching.
Old Dec 1, 2007 | 11:19 PM
sixs929's Avatar
Wow. I just checked the print, and it ain't pretty. The brown and black wire coming off the fuse is the culprit, but that damn thing goes to:
1. Speed sensor connector
2. The last connector before the turn signal switch, where the wire splits and goes to the turn signal switch AND the horn switch
3. Instrument cluster connector
4. The brake/tail/license plate light bulb sockets
If it was me, I'd disconnect the connectors I mentioned and put an ohmmeter on that brown/black wire at the fuse and look for a grounded reading. If there isn't one, the wiring harness is good, and then you'd have to start checking the individual components.
That ain't much help, is it. I'll shut up now...........
Old Dec 8, 2007 | 03:09 PM
lexiconby's Avatar
make sure you go and get yourself a box of 10A fuses...just in case you blow a few more while trying to troubleshoot the problem. hope you get lucky with your volt meter. electrical problems are always tricky to figure out...good luck.
ZBike
Mar 24, 2012 04:38 PM
Cobretticuz
Jul 30, 2011 02:16 AM
bluefire7321
Feb 19, 2007 12:30 PM
soapdish
Oct 14, 2006 12:33 AM
galvarado
Jan 6, 2006 03:20 AM
