blowing fuses?
Old Oct 12, 2006 | 11:24 AM
soapdish's Avatar
Default blowing fuses?
was riding my cbr when all the sudden the bike shut down. I checked the fuse an it was blown so i replaced it and it blew again. checked for frayed wires ,nothing ,cant figure it out need some help what do u think?
Old Oct 12, 2006 | 01:26 PM
slowpoke's Avatar
Default RE: blowing fuses?
Definitely a short where current is flowing directly to ground. Looking for pinched or damaged wires between the seat and frame, or gas tank and frame is a good start. If the wires look good, you will have to get a ($10) Self-Powered Test Light (Continuity Tester). Use the instructions to find which wire or component contains the short.
Old Oct 12, 2006 | 02:53 PM
mikequinn's Avatar
You could have a dead short in the rectifier.
does it blow as soon as you put a new one in? or does it not blow till you switch the ignition on?, if its the latter it's not the rectifier
Old Oct 14, 2006 | 12:33 AM
sasakiman's Avatar
Similar thing happend to me. Bike shut down on the freeway, blown fuse. Replaced the voltage regulator, no problem since.
hmm
May 8, 2012 07:57 AM
ZBike
Mar 24, 2012 04:38 PM
jasonp
May 8, 2007 01:24 AM
bluefire7321
Feb 19, 2007 12:30 PM
galvarado
Jan 6, 2006 03:20 AM
