Fuses Blowing
Old Jan 5, 2006 | 03:36 AM
galvarado's Avatar
Default Fuses Blowing
I have an 05 CBR 600RR. I recently added a Two Brothers Titanium slip on exhaust, Competition Werkes Fender Eliminator Kit and a Clear Alternatives Integrated Taillight. Looks great, but fuses keep blowing. The digital speedometer will completely turn off and the running light will also go out. The signals continue to work. I drive from the mechanic shop and the fuses blow at different times. Sometimes two days later...sometimes the moment I drive off the lot. I replaced the integrated taillight, but that didn't solve the problem. The mechanic stated the the wires appear to be OK. Clear Alternatives stated that it was not their product that was causing the fuses blowing. I'm now placing the stock taillight back on to see if the fuses will begin to blow. If you have any advice it would be greatly appreciated. Thanks.[:@]
Old Jan 5, 2006 | 05:04 AM
shraz's Avatar
Default RE: Fuses Blowing
1st check your battery if the plugs + and - are hooked right and tight.
if still doesnt work
-remove the plugs or wires of blinkers
-remove/unplug anything you've added to the bike that is useless :P
-put new fuse in the box
-try!
-enjoy searching at a malfunction wire that is cut, touching something that it shouldnt, crushed, missing, etc somewhere
-headlight
-speedo
-etc
-try using a new battery
Old Jan 5, 2006 | 05:51 AM
pizzle954rr's Avatar
I was expecting to click on your attachment and see a pic of the taillight but much to my delight it was two fine ladies forced to take a picture with a man cheesing like the first day he got his motorcycle!![sm=Flahssssss.gif] Start from scratch, put your factory taillight on and see if you pop any fuses. Retrace your steps and youll figure it out.
Old Jan 5, 2006 | 08:11 AM
doncollins's Avatar
Retired Administrator
Since the fuse/s aren't blowing every time you power up... I'll assume you're wiring is good. If it's random like you said, then I'd guess that one of your add ons are causing a short over time. I always solder and heat/shrink wrap my connections on a bike to make sure there is no possible way for a short/grounding problem. Maybe one of your components has a design/manufacturing flaw and it takes a few bumps before it shorts out. Go back stock and try one modification at a time to see when the fuse/s start to blow.
Old Jan 5, 2006 | 02:02 PM
slowpoke's Avatar
There are only three wiring problems. Opens, shorts and grounds. An open means that the circuit has been interrupted by a broken wire or bad switch. A short is flow directly to ground without a load, such as a wire from the positive side of the battery touching the ground. A ground is similar to a short, but on the ground side. A blown fuse or cooked wiring indicates a short. How do you find it?
Using the wiring diagram, isolate your circuits by disconnecting all the grounds and insulating them (with tape) so they don't make contact. Get a continuity tester, (a self-powered test light, $10 from Sears), and connect the aligator clip to ground and probe your connectors. Any circuit that still has continuity contains the short. Pinched wires can short even though the insulation appears intact.
Old Jan 6, 2006 | 03:20 AM
galvarado's Avatar
Thanks everyone! I'll continue on my journey of finding a solution. The CBR Forum is AWESOME! I should of joined months ago. Take it easy.
hmm
May 8, 2012 07:57 AM
ZBike
Mar 24, 2012 04:38 PM
jasonp
May 8, 2007 01:24 AM
bluefire7321
Feb 19, 2007 12:30 PM
soapdish
Oct 14, 2006 12:33 AM
