Fan blowing fuses
Manual fan switch install
Hey guys,
I keep digging through threads, researching the problem I'm having with my fan blowing a fuse immediately when it kicks on, and I think I'm just going to run a manual switch to it.
Where have you seen switches mounted on these bikes?
Do I need to install a fuse somewhere?
Looking at radio shack switches, I see one that says it's SPST 16 amp, 125 volts. Is this too much, too little?
I'm not very knowledgable on this stuff. I can do the soldering/install well, but I'm not very good with knowing what I need.
Any input is appreciated, thank you.
Fan blowing fuses
I just started another thread on running a switch to manually turn the fan on and off, but was recommended to start a thread on finding the real solution....so here is my problem:
My fan kicks on when it is supposed to, but when it does, it blows the fuse immediately.
That's where I am.
That's where I am.
So I checked it out yesterday, looks like you're spot on. The shroud around the fan is bent in a little at the top where the bracket is welded on. The fan is hitting it and stopping. I wasn't able to bend it without taking it off so I'll have to tackle it tonight or tomorrow. Thanks for your help, I'll let you know.
