Help! Keeps blowing speedo fuses!
RE: Help! Keeps blowing speedo fuses!
Wow. I just checked the print, and it ain't pretty. The brown and black wire coming off the fuse is the culprit, but that damn thing goes to:
1. Speed sensor connector
2. The last connector before the turn signal switch, where the wire splits and goes to the turn signal switch AND the horn switch
3. Instrument cluster connector
4. The brake/tail/license plate light bulb sockets
If it was me, I'd disconnect the connectors I mentioned and put an ohmmeter on that brown/black wire at the fuse and look for a grounded reading. If there isn't one, the wiring harness is good, and then you'd have to start checking the individual components.
That ain't much help, is it. I'll shut up now...........
