Intermittent electrical problems
Old 09-14-2011, 09:01 PM
rnareppa's Avatar
Registered Users
Default Intermittent electrical problems
I did some search on the forums for the problem I am having but did not find anything specific, so here it goes.
The speedometer on my 1997 drops to zero intermittently, as if there is a loose connection. I saw some postings that said to check the speed sensor which I will do in the morning daylight now. The other (maybe related) issue was that whenever I had the turn signal on, the bike showed signs of turning off, and I noticed the front headlights were flickering too. I made it back home, restarted the bike and the lights were fine. Maybe it is a loose connection playing havoc, but just wanted to post this to find out if the experts on this forum have some suggestions or if you have experienced this before....afraid of stalling on the highway!
Thanks in advance!
Old 09-15-2011, 05:23 AM
zaqwert6's Avatar
Nov 2011 ROTM
Most of those sound like a ground issue. I'd start there , ground at the battery, at the frame, terminals and cables.
Old 09-16-2011, 12:07 AM
exciter900rr's Avatar
AND, Welcome to being a fireblade owner!
Old 04-18-2013, 08:58 AM
rnareppa's Avatar
Registered Users
BTW, just to close out this "old" discussion, it was a battery grounding issue, tightened up all the connections and everything was back to normal......thanks zaqwert6.
kyslow
09-18-2013 01:03 PM
subyman1440
F2 Tech
02-20-2012 09:53 PM
wisfal
F2 Tech
01-20-2012 08:55 AM
dcaldwell
10-06-2009 10:20 PM
Cyber
02-09-2009 04:11 AM
Quick Reply: Intermittent electrical problems
