Electrical problems
Old Jan 18, 2012 | 01:53 AM
wisfal's Avatar
Registered Users
Default Electrical problems
I have been working on my bike have come into a problem. I have just replaced the R/R and Battery within the last week. All is good with that stuff. I'm afraid that it seems that the battery isn't getting recharged by the charging system. I could be wrong but what makes me come to believe that is when I have the bike running good and well, even at operating temp. If I disconnect the positive cable from the battery, the bike will continue to run...but very poorly, sounds like its just near death and cannot rev the bike at all, barely idles. Connect the cable again to the battery and works fine. Could this be my stator? Any help would be much appreciated.
Old Jan 18, 2012 | 06:00 AM
74demon's Avatar
What is your charging voltage at 4-5k rpms?
Old Jan 18, 2012 | 08:53 AM
JankCibberf2's Avatar
check your connection from your stator to the white plug next to the battery. it could be slightly disconnected, or it could be burnt
Old Jan 18, 2012 | 09:47 AM
Project96's Avatar
Don't disconnect the battery when its running. What's the charging volts? Once we get that if its bad we can check the stator output for ac volts & grounding.
Old Jan 19, 2012 | 02:17 PM
wisfal's Avatar
Registered Users
Just checked it out. 14.20-14.40 @idle 13.60-13.70 @ 4-5k rpm.
Old Jan 19, 2012 | 07:31 PM
74demon's Avatar
i would expect the opposite, they dont charge at idle. to check to stator: the three pins should have continuity between them, and no continuity from each pin to ground. anything not like it should be, means bad stator.
Old Jan 19, 2012 | 11:20 PM
Project96's Avatar
Not necessarily...depends if it is a Y wound stator or a Delta wound stator.
Between 13-15 VDC is good. Anything over or under & you have charging problems.
Another way to check for a grounded stator is to use a test light. Connect the clamp lead to the (+) positive battery terminal & touch the 3 pins coming out of the stator. If the light comes on, the stator is grounded & bad. If is doesn't light then check AC output & continuity with a meter. They don't teach that, just something I have come up with over the years & yeah...it works.
Old Jan 19, 2012 | 11:23 PM
74demon's Avatar
Good to know.
Old Jan 20, 2012 | 08:55 AM
Ya man i never knew that either. Good looking out!
dcaldwell
Oct 6, 2009 10:20 PM
thetrick13
Aug 11, 2009 10:13 AM
f3gatorfan3388
Nov 19, 2007 02:28 PM
rblevins4130
Nov 10, 2007 04:36 PM
dizzie56
Jul 9, 2006 01:59 AM
