Push pull cables too stiff.
Old Jul 22, 2021 | 04:25 PM
Denali's Avatar
Default Push pull cables too stiff.
Okay, it’s time I put my frustration on others. Haha. So my throttle cables were too damn tight and it was difficult to get them on. When I do. They’re so stiff to the point I can’t even move the throttle. I bought some new ones. Same thing. And yes I’ve fully adjusted them to the best of my knowledge. As well as lubed them
i did notice that the one on the lower end of the carb. The push? Is so tight that it’s pulling the throttle tube too close to the housing. And that one isn’t adjustable so I’m just kinda mind boggled. Please help -
Denali
Old Jul 22, 2021 | 06:13 PM
A couple things.
The obvious statement is there shouldn't be that kind of resistance.
When the bike is at zero throttle the top cable should be the one that is extended. As you twist the throttle the upper and lower trade places in length. Are you positive that you have them in the correct placement?
I generally don't do much adjustment at the throttle end of the cables. For me that end is for very minor tweaks. I do the majority of my adjustment on the carb end. I accomplish this by adjusting the nuts that are on the threaded end after the cables are in the holding bracket. Doing this has gotten me mostly where I need to be. There is a small amount of play in the throttle when you go from zero to something. I adjust most of that out.
Are you sure you have the cables routed correctly?
Old Jul 23, 2021 | 01:32 PM
Denali's Avatar
Originally Posted by hamlin6
A couple things.
im not positive. I cannot understand why I’m getting this much resistance. It’s driving me nuts and holding back my entire project
Old Jul 23, 2021 | 04:35 PM
When they are disconnected do they have the same amount of resistance or do they move freely?
Old Jul 23, 2021 | 06:56 PM
Denali's Avatar
when the lower one is disconnected it moves perfectly( the push?) I’m thinking that cable is too tight. What sucks is there no way to adjust it
cuetip
Dec 28, 2011 07:15 PM
filthydanger
Feb 24, 2011 01:04 AM
Clorox09
Apr 5, 2009 09:40 PM
94cbr600kid
Dec 4, 2008 05:32 AM
mccannf3
Mar 8, 2007 12:07 AM
