throttle handle sticks
Old Feb 1, 2010 | 03:29 PM
filthydanger's Avatar
Default throttle handle sticks
i just got my bike and one thing i noticed is that the throttle sticks. the handle wont snap back when i let go, so i have to move it back myself. is there an easy fix for this or will i need to buy a new handle ( if so, where is a good place to get one? )
Old Feb 1, 2010 | 03:39 PM
Bently600's Avatar
welcome to the forum filthy... pics of your new ride?
your throttle sticking could be a lot of things. but it is dangerous...
-the grip could be catching on the bar-end weight or the break perch.
-the throttle cables could be super dirty, preventing carb/throttle spring from pulling.
-could be carb/throttle spring is too old and not pulling hard enough
Check that the grip is moving freely first. then check throttle cables for ease of movement.
Old Feb 1, 2010 | 08:20 PM
JimmyHoffa's Avatar
or your clip-on could be bent like mine, since both my bikes became mine after an explosive flip down a highway. The throttle tube is stiff, and will want to be straight even if the clip-on is bent, so it will bind and not return properly.
Old Feb 2, 2010 | 01:32 AM
jtkardel's Avatar
You also might want to take off the throttle tube and check the clip-on's surface beneath it. My clip-on had rusted a bit under the grip and prevented it from moving freely. Some light sanding took care of that.
Old Feb 4, 2010 | 10:52 AM
flyboy1011's Avatar
I just unscrewed both nuts right below the throttle tube and shot a little WD40 down and twisted the throttle work it in...snaps back like new now. for now atleast lol.
Old Feb 4, 2010 | 05:18 PM
BDT's Avatar
BDT
Check the adjustable screws on the wires coming out of the housing. They might be too tight.
Old Feb 4, 2010 | 06:14 PM
letsride's Avatar
First remove the bar end and see if that solves the problem,if that doesnt work,check throttle tube and cables and check as stated above.
Old Feb 4, 2010 | 06:30 PM
Preid's Avatar
My throttle sticks and Im now used to riding with it. Sometimes when Im riding on the motorway or in slow moving traffic I go no handed (I always keep a safe distance). Its cruise control essentially.
Old Feb 5, 2010 | 10:29 AM
JimmyHoffa's Avatar
That is both kinda awesome and incredibly sketchy at the same time.
Old Feb 10, 2010 | 10:53 PM
mlbricker21's Avatar
mine was doing the same thing and shooting wd40 under it worked fine for mine too as mentioned above
