Throttle cable replacment
Old Mar 7, 2007 | 12:25 AM
mccannf3's Avatar
Default Throttle cable replacment
I hope I'm putting this in the right spot, but when I got my bike the previous owner had laid it down on the right side and broke the bar end and throttle tube. I have had a sticking throttle since I got it and thought it was the throttle tube rubbing. so i bought a new throttle tube and I'm trying to in stall it but can't seem to get the throttle cables off the old tube. does anyone have any useful info that might help me get the cables off?
Old Mar 7, 2007 | 12:47 AM
kwong2001's Avatar
Default RE: Throttle cable replacment
Good luck, I replaced mine and it took me like 2 hours to get the throttle cables off...and i still have no idea how I did it.
Old Mar 7, 2007 | 02:05 AM
abadfish's Avatar
Try this first... adjust the throttle cables to give as much slack as possible. If you're lucky, you'll give enough slack to get them off.
If that doesn't work, then most grief-free way to do this is to take off the tank, airbox, and carbs to get the throttle cables off on the carb end. This will allow you to get the cables off easily on the throttle tube. It sounds like a lot of work (and it probably is), but it'll be a struggle to do it otherwise.
Old Mar 7, 2007 | 11:36 AM
Sproutf3's Avatar
Registered Users
when i took mine apart it just took a flat head and some cuss words[:@] i agree with badfish goin to the carb's is a lot of work, but it'd make the other end easier
Old Mar 8, 2007 | 12:07 AM
mccannf3's Avatar
Right on guys, I have removed my tank and intake system and the cables are right there. Looks pretty simple from this point, Thanks again!
airforce123
Apr 4, 2012 10:24 PM
cbr6rider
Apr 20, 2011 08:57 AM
newtjrjrjr
Aug 19, 2008 12:56 PM
283racin
Apr 30, 2008 11:16 PM
angryscientist
Sep 29, 2006 07:51 PM
