Fuel Pump Fault.
Old Jul 21, 2021 | 09:02 AM
Parrotperson's Avatar
Default Fuel Pump Fault.
HI guys / Gals.
I'm wondering if someone can give some advice please.
I have a UK model 97 CBR600F3,
I have owned the bike for a few years but have been very neglectful I have to admit.
I recently decided to get the bike running again after it being left stood for nearly 18 months.
Needless to say, the bike cranked but nothing after that.
I removed the tank and carbs, and gave them a thorough clean out.
After being refit I have still got an issue where the bike would crank but not fire.
I put a small amount of fuel directly into the carbs and low and behold the bike started briefly,
So I set a new fuel line upto the carbs on gravity feed from the Tank and the bike runs like this.
I set the bike back to run from the fuel pump, and nothing.
I replaced all fuel line from the tank to the pump, replacing the inline filter also.
nothing so its not a blockage.
I have replaced the fuel pump relay,
The fuel pump relay connector has a reading of 0.2 - 0.6 when the bikes "On" but not cranking,
and its between 2 and 6v when cranking.
I have jumped the fuel pump direct from a spare battery and the pump also works.
And when testing the fuel pump connector the readings are the same as the fuel relay.
0.2 - 0.6 when "on"
And between 2 and 6v when cranking.
Does anyone have any further ideas why my bike won't work on the pump but will when direct carb fed???
Old Jul 29, 2021 | 09:14 AM
Did you perform the flow test on the pump to verify how much it's pumping?
Old Jul 29, 2021 | 09:19 AM
I havent as the pump doesn't run when connected to the bike it only runs off a standalone battery when connected with copper wire
Rider123
Jun 29, 2021 08:43 AM
landfast
Jun 14, 2011 05:43 PM
mitchedwards81
Nov 25, 2009 05:40 PM
moto9
Sep 14, 2008 03:22 PM
frankinbarnes
Mar 20, 2007 11:56 AM
