tune up
Old 05-26-2013 | 12:21 PM
jamescbr87's Avatar
Registered Users
Smile tune up
hi there. is there a thread or pics on how to change the oil and spark plugs..also sync carbs and clean them
Old 05-26-2013 | 12:47 PM
CorruptFile's Avatar
June 2013 ROTM
https://cbrforum.com/forum/cbr-600f-...1990-a-128286/
All in the book. Youtube carb cleaning, its easy.
Old 05-26-2013 | 04:13 PM
dodger79's Avatar
Hi mate
The plugs on my bike are standard ngk's not iridium and need an 18mm deep socket or box spanner/wrench. I think there are also 16mm plugs that fit too.
Might be handy to know if you don't have the tool kit.
Let us know if you're unsure of something when you do the carb clean and oil and filter change. I've just changed my oil and filter and cleaned the carbs a few months ago. Don't take them apart and don't mess with the mixture screw unless you're an expert. A basic clean of the jets and passages and the other stuff in the float bowls is normally is all that's needed.
I didn't synch my carbs so I might learn something from this thread if you do yours.
Rog
Old 05-26-2013 | 07:22 PM
Davewesh's Avatar
Default Oil drain screw?
I've got a question to kinda of piggy back off of the OP's question, The oil drain screw, is on the left side of the bike next to the Exhaust? the illustration in the manual makes it kinda of difficult considering my bike never had the Fairings on it so just double checking.
As far as i can tell, syncing the carbs is fairly easy, Ill be doing this once i get the Major safety parts of my bike in. So ill try and do a write up on that when i can... No promises though >_> lol
Old 05-26-2013 | 11:37 PM
cBrentb's Avatar
download shop manual
Old 05-27-2013 | 05:58 AM
dodger79's Avatar
Yeah the drain screw is on the left side (near side/curb side in UK) if you were sat on the bike. It's at the bottom of the oil pan/sump near the exhaust and I think needs an 18mm socket. I put a hi-flo oil filter on mine that I got for £7 from a bike shop. I can recommend them - look good quality to me.
Rog
Old 05-28-2013 | 01:03 AM
Zachy72's Avatar
Rog
it's a 17mm, just did mine a month ago.
The spark plugs are the 18mm
Old 05-28-2013 | 05:20 PM
dodger79's Avatar
Oops - cheers Zachy72 you're quite right bro
Congee
05-30-2014 12:37 AM
stretch_the_apex
01-30-2011 12:58 PM
F4ISmurf
06-01-2010 12:41 PM
red99f4
03-04-2010 11:32 PM
JMart
06-29-2007 09:20 AM
