tune up
hi there. is there a thread or pics on how to change the oil and spark plugs..also sync carbs and clean them
https://cbrforum.com/forum/cbr-600f-...1990-a-128286/
All in the book. Youtube carb cleaning, its easy. |
Hi mate
The plugs on my bike are standard ngk's not iridium and need an 18mm deep socket or box spanner/wrench. I think there are also 16mm plugs that fit too. Might be handy to know if you don't have the tool kit. Let us know if you're unsure of something when you do the carb clean and oil and filter change. I've just changed my oil and filter and cleaned the carbs a few months ago. Don't take them apart and don't mess with the mixture screw unless you're an expert. A basic clean of the jets and passages and the other stuff in the float bowls is normally is all that's needed. I didn't synch my carbs so I might learn something from this thread if you do yours. Rog |
Oil drain screw?
I've got a question to kinda of piggy back off of the OP's question, The oil drain screw, is on the left side of the bike next to the Exhaust? the illustration in the manual makes it kinda of difficult considering my bike never had the Fairings on it so just double checking.
As far as i can tell, syncing the carbs is fairly easy, Ill be doing this once i get the Major safety parts of my bike in. So ill try and do a write up on that when i can... No promises though >_> lol |
download shop manual
Originally Posted by Davewesh
(Post 1234438)
As far as i can tell, syncing the carbs is fairly easy, Ill be doing this once i get the Major safety parts of my bike in. So ill try and do a write up on that when i can... No promises though >_> lol Rog |
Originally Posted by dodger79
(Post 1234506)
I think needs an 18mm socket
Rog The spark plugs are the 18mm |
Originally Posted by Zachy72
(Post 1234631)
it's a 17mm, just did mine a month ago.
