Get a tune up?
Old May 30, 2010 | 04:35 PM
F4ISmurf's Avatar
Default Get a tune up?
Hey guys I was wondering what I should expect to pay for a tune up on a 2002 f4i?
Old May 30, 2010 | 07:38 PM
Combat_F4i's Avatar
What do you want done? A tune up would be to me oil/filter/chain tension adjustment and every 500KM or so chain lube.
A full tune up on a new to me bike would be new tires, re-bleed front and rear brakes with new fluid, coolant flush, new oil/filter, brake pad and air filter check, check the plugs, chain tension and asjutment, suspension setup.... ect
sooo..... brings me to my question. what kinda tune up is needed?
Old May 30, 2010 | 11:19 PM
j4eric's Avatar
dyi, you have to learn sometime...lots of info here on how to....
Old May 30, 2010 | 11:29 PM
F4ith's Avatar
diy like eric said. Everything combat listed, except new tires, is really easy, and fun imo, to do yourself. It may require a few basic tools that most homes should have.
If you really don't want to diy, I believe each shop has a tune up fee (different depending on shop) and then they toss in the cost of whatever is needed, ie new oil/right head lamp. They'll charge you that initial tune up fee, plus the cost of the new oil/filter/lamp. I don't remember the specifics. I was dumb and didn't know anything about bikes when I brought my first bike (F2) to a shop, which cost me roughly $400 for the tune up. They fixed a clogged tube, replaced the high beam bulb, and oil/filter.
Old May 30, 2010 | 11:30 PM
F4ISmurf's Avatar
i reckon it would be a more extensive one. its an 02 with 11k miles on it. ill take a look at the how too threads. im a mechanic by trade but have never worked on a bike before. can i maybe find a checklist of things needed ever x miles?
Old May 30, 2010 | 11:42 PM
Kuroshio's Avatar
http://www.stephygee.com/f4imanual.zip
In the maintenance section it the checklist you're looking for
Old May 31, 2010 | 12:02 AM
F4ISmurf's Avatar
thanks for the help guys.
Old May 31, 2010 | 05:02 PM
usetheffours's Avatar
If your a mechanic you'll have no problems working on your bike. Here a link to the full honda manual.
Old Jun 1, 2010 | 11:41 AM
maldy21's Avatar
i remember the shop by me charges $85 for an oil change. then it's like $80 an hour for other work. do as much as you can yourself. the oil, spark plugs, air filter and radiator are all pretty easy and it's easier also if you do them all at the same time because you have to get through the af to get to the spark plugs and radiator easily anyways.
Congee
May 29, 2014 11:37 PM
stretch_the_apex
Jan 30, 2011 11:58 AM
red99f4
Mar 4, 2010 10:32 PM
LlanoSV
Jul 26, 2007 08:27 AM
JMart
Jun 29, 2007 08:20 AM
