HELP!!! IT JUST KEEPS DYING
Old Dec 20, 2006 | 10:23 AM
bwp777's Avatar
Default HELP!!! IT JUST KEEPS DYING
I HAVE A 2004 CBR 1000 AND IT HAS DIED ON ME 2 TIMES WHILE UPRIGHT. ONCE WHEN APPLYING POWER AND ONCE TOOLING AROUND. THE TIP OVER SENSOR IS IN THE UPRIGHT POSITION AND IT DOES NOT FLASH A CODE. ANY ADVISE IS NICE
Old Dec 20, 2006 | 02:36 PM
Onarom's Avatar
Default RE: HELP!!! IT JUST KEEPS DYING
Is the battery dead? it so, I would check your regulator rectifier. I had a problem with my regulator rectifier on my 97 cbr and I have heard that 2004 also had a small issue with them.
Old Dec 20, 2006 | 05:18 PM
bwp777's Avatar
Brand new battery so I will look into the rectifier.
Old Dec 20, 2006 | 08:10 PM
de goose man's Avatar
Spark Plugs maybe had the same issue before with my F3....
Old Dec 22, 2006 | 09:26 PM
Blue Fox's Avatar
Retired Moderator
Mine kept dying (then it wouldn't start). Found out it was bad (dirty) gas. (Gas Station flooded with dirty water the night before) I drained the tank, refilled the tank with new gas, haven't had a problem. Don't know if that's your problem, but it's a thought.
Old Dec 22, 2006 | 10:49 PM
joker's Avatar
Make sure your ground cable is secured tightly on the battery post and on the motor. I've had problems very similar. good luck.
Old Dec 24, 2006 | 04:39 PM
bwp777's Avatar
Thanks dudes I will try all options before taking her to the dealer
Old Jan 18, 2007 | 12:33 PM
1fasthonda's Avatar
Your injetors might be blocked. Try running a known fresh, clean gas through it. You could also try put fuel injetor cleaner in the gas.
cobra989
Aug 5, 2013 01:46 PM
seand88
F2 Tech
25
Jun 27, 2013 11:55 PM
STRETCH15
May 27, 2012 07:15 PM
akcbrf3
Oct 16, 2007 01:35 AM
telgren
Oct 15, 2006 01:42 PM
