ok valves i think
Old 03-12-2009, 09:40 AM
JRad1000's Avatar
Default ok valves i think
i got some ticking noise coming from the valves i pulled it a part and turned it over a few times and everything seems to be working properly and nice and snug but the noise comming from the valves sounds like they are sloppy or loose, suggestions??? should i just take her in and have them do a full tune up including checking the valves or you guys think its somthing i can pull off myself?
Old 03-12-2009, 01:10 PM
malbojah's Avatar
If you do it yourself, your going to need the service manual (Shadow will post a link), a set of feller gauges, and the Honda tool that it used to tighten the locknut while you hold the tappet adjuster. (It's a 10mm deep socket with a handle welded on it)
Also, depending on how many miles you have, you might want to consider replacing the valve cover gasket.
Old 03-12-2009, 07:56 PM
Imo000's Avatar
Don't really need the Honda tool. You can used a pair of locking pliers and a regular deep 10mm socket. Grind the sides of the socket down a bit so the plier can grab onto it and that's it!
Old 03-12-2009, 09:21 PM
You can definitely do it yourself. You'll do a much better job than some shop. You can do it in a day. IMO000 is right you don't need the tool, but it sure makes it nice.
Old 03-12-2009, 10:18 PM
Shadow's Avatar
Old 03-12-2009, 11:24 PM
bluebeard's Avatar
Valves are easy. The tools are cheap & easy to modify. Depending on which year your bike is some are Allan key (socket head) adjusters & some use a small screwdriver. All use the same locknut. Have a look through the "search" function as there are how to's on the subject. Have fun.
Old 03-13-2009, 10:26 AM
JRad1000's Avatar
Default thanks@!
thanks guys thanks a million ill have a look over some things and see what i can do... i think the only thing im going to need is the feeler gauges... oh and i have a small vid of her running and some rev's as well as a peak of the body work so far so ya know this bike was pretty much smashed to peices and i have been rebuilding her since aprox. dec
Ill post the link in a new thread...
Old 03-13-2009, 07:42 PM
Imo000's Avatar
Harbor Freight, Sears or any of the auto parts store will have the feeler gauges that you need.
CorruptFile
07-19-2019 12:57 PM
camaroloverx4
09-17-2012 06:56 PM
Kuroshio
09-29-2009 06:43 PM
lonewolfcbr
05-07-2008 10:33 PM
929BEATSTI
04-24-2008 04:38 AM
Quick Reply: ok valves i think
