ok valves i think
ok valves i think
i got some ticking noise coming from the valves i pulled it a part and turned it over a few times and everything seems to be working properly and nice and snug but the noise comming from the valves sounds like they are sloppy or loose, suggestions??? should i just take her in and have them do a full tune up including checking the valves or you guys think its somthing i can pull off myself?
If you do it yourself, your going to need the service manual (Shadow will post a link), a set of feller gauges, and the Honda tool that it used to tighten the locknut while you hold the tappet adjuster. (It's a 10mm deep socket with a handle welded on it)
Also, depending on how many miles you have, you might want to consider replacing the valve cover gasket.
thanks@!
thanks guys thanks a million ill have a look over some things and see what i can do... i think the only thing im going to need is the feeler gauges... oh and i have a small vid of her running and some rev's as well as a peak of the body work so far so ya know this bike was pretty much smashed to peices and i have been rebuilding her since aprox. dec
Ill post the link in a new thread...
