gauge disassembly
Old 05-21-2011, 09:04 PM
ganzey's Avatar
Default gauge disassembly
hey i got a quick question....i was wondering if the gauges come apart to the point where i can remove the reddish/orange paint and redo it in blue? i did it on my truck but i wasn't sure if these gauges can come apart without breaking?
thanks
ps-1996 cbr1000f
Old 05-21-2011, 09:13 PM
MadHattr059's Avatar
I'm sure it's possible, cause there is some guy that makes a internet business out of doing that very thing. As far as ease of doing it, not sure. Let s know how that works out with a post-post.
Thanks, Ern
Old 05-21-2011, 09:41 PM
ganzey's Avatar
alrighty, ill give it a shot. the worst part about doing it on my truck was that i didnt realize after i removed the needles, the shafts continued to spin, and i spent hours recalibrating them.....but they were electric so im guessing with cable driven they should be straight forward,,,
and with that being said, can anyone recommend me a link to some hid headlights? thanks
Old 05-21-2011, 11:26 PM
robbiebgraham's Avatar
Are you talking about the speedo and rev counter? If so, yes they do come apart as I have shifted the needle on my speedo.
Old 05-22-2011, 01:25 AM
Shadow's Avatar
Yes they do come apart.
If you look in the "how to" section, I did a write-up on how to remove the panel.
https://cbrforum.com/forum/how-tos-8...-1000f-100888/
Once that is done, there are screws holding the panel together, about 8 I think.
The needles can be a b1tch to get off if they have been glued in.
Use the correct tools or you WILL stuff up the speedo. Take it to an instrument tech or ask his advice.
I replaced my clock face with a Kilometer one, and it works fine.
The speedo works on a magnetic system, so even with the cable it's not a direct drive. The cable spins a magnetic disc.
When you have it free of the cable, gently push the needle up to about 100 and it will slowly return until it hits the stop. It's quite important to mark where the shaft stops or the needle wont give you correct figures.
Good luck with it.
And buying replacement face plates is easy - numbers of guys on e-Bay do it, just about any colour you could ask for.
From Germany
http://cgi.ebay.de/Honda-CBR-1000-F-...item1c1a2388ab
These are in Kilometers but you get the idea.
Oh and if you're planning to replace gauges not all years are the same. Face plates fit differently.
swoop4321
05-19-2013 12:56 AM
bohdan
11-19-2012 10:28 PM
Atrom
05-01-2011 12:46 PM
dagus
02-05-2009 02:39 PM
MidnightG35X
09-08-2008 05:34 PM
Quick Reply: gauge disassembly
