How To's Show us what ya did and how ya did it!
Instrument panel removal - 89-91 1000F
Old Apr 17, 2009 | 09:33 PM
Shadow's Avatar
Default Instrument panel removal - 89-91 1000F
How to - clock removal CBR1000F
How to remove your clock panel on the Mk2 CBR1000F (89-91)
Later models may vary slightly.
Summary -
1 Remove the panels covering your fuse box and radiator cap 3 screws each. (Pic 1)
2 Under the fuse and radiator panels, you will see screws securing the windscreen infill panel. Remove them . 1 screw per side (pic 1 above)
3 Remove the screws holding the screen/instrument infill panel (Pic 2 below)
4 Remove the infill panel (may require some "jiggling and bar movement, but comes out) (Pic 3)
5 There are two connector blocks for the gauge panel, located under the right radiator panel - disconnect them (one black, one red) Pics 4 , 5 and 9)
6 Pic of infill panel removed (Pic 6)
7 Remove the bolts securing the gauge panel to the fairing frame, don't lose the rubber grommets ! (Pic 7and 8
8 Remove speedo cable (Pic 10+11)
9 Lift gauge cluster out of the frame.
Done !
http://photobucket.com/shadowCBR1000F Pics 1-11
Details below :-)
Done !
Replace in reverse order. Don't overtighten bolts on gauge cluster or you may break plastic lugs !
Bulb holders can be clearly seen.
Remember - These bikes take Honda bulbs which have different "lugs" to std bulbs !
Either use Honda bulbs (expensive) or buy adapter rings on e-Bay Motors, or just trim the tabs on std bulbs - the spring will hold them in place anyway.
Old Dec 3, 2012 | 09:10 AM
sergio3d's Avatar
I can't see any pictures
Old Dec 3, 2012 | 09:20 AM
hawkwind's Avatar
The link works for me Sergio, it may be because of your location or something?
You can download the workshop manual from here, might help.Workshop Manuals - CBR Forum - Enthusiast forums for Honda CBR Owners take your pick there are plenty to choose from.
Old Dec 3, 2012 | 10:15 AM
Sprock's Avatar
Yup
Linky still worky from the good ole USA too
Old Dec 3, 2012 | 04:37 PM
ozzyAL's Avatar
pics aren't coming up for me either , but if u click onto the photobucket link you can see the there
Old Dec 3, 2012 | 06:10 PM
Sebastionbear1's Avatar
I'm with Sergio and OzzyAl,
The inserted pictures I cannot see, but the link to Shadows Photobucket works
Great 'How To' Shadow by the way.
Cheers, SB
Old Dec 11, 2012 | 12:38 AM
Shadow's Avatar
I thank you good Sir - I'll see what I can do about the pics.......
Old Nov 12, 2013 | 04:56 PM
Chippy211's Avatar
Excellent How To Shadow.
That takes care of that job on my bike when I get home, it will be a huge help.
Thanks
Kurt Robert Lindqvist
Aug 27, 2012 07:58 PM
Johnathon Graddy
Feb 13, 2011 10:58 PM
smr123
Dec 28, 2007 05:02 PM
recker
Jul 10, 2007 12:30 AM
CBR600RRBLUE
Apr 7, 2006 08:34 AM
