Aftermarket Discuss aftermarket upgrades to your CBR here.
Flush mount LED question
Old Mar 11, 2007 | 10:24 PM
Cable's Avatar
Default Flush mount LED question
First offI have done a search and haven't found what i'm looking for. I have a set of Hotbodies flushies for an06 Cbr600rr and i was wondering if anyone knew what kind of LED's were used and howmany. I'm looking for voltage, whatts, Ohms anythingthat could help would be appriciated.
Old Mar 12, 2007 | 12:04 AM
dragonium25's Avatar
Default RE: Flush mount LED question
Why do you need to know? Voltage is most likely 12V cuz that's what the battery is and so is most aftermarket turn signals.
Old Mar 12, 2007 | 12:52 AM
Cable's Avatar
I want to change the color of the LED's. The voltage for the turn signal system is to my knowledge 12V. (That would make sense) but I'm not sure about for each LED. If anyone has any experience with this I would like to know. I have a fairly good understanding of electronics if that helps at all.
Old Mar 12, 2007 | 06:30 PM
Triax's Avatar
what size leds are they? 5mm are about 1 to 1.8 volts per led and the 3mm leds are less than 1 volt.
Old Mar 12, 2007 | 07:20 PM
Cable's Avatar
I'll have to find out tonight. I haven't taken the Flushies apart yet. I may take a trip to radio shack with them as well to see what i can find out there.
Old Mar 26, 2007 | 01:24 AM
Ocelaris's Avatar
Actually, 5mm and 3mm and any mm are the same as long as the power is the same. Most LEDs are around 20mA and red/green/orange are 2.5 voltage drop, and white/blue are 3.5 typically.
Why are you trying to replace them? Not bright enough? LEDs are way way way dimmer than bulbs... same efficiency, but a single 5mm LED puts out about 3/4 lumen. If they are standard round kind, 5mm, pretty much any LED of similar color will be a direct replacement if you solder/desolder them in place. You honestly can't get enough brightness out of LEDs in signals to pass DOT approval.
I would never put an aftermarket LED kit on my bike, they're just not bright enough. Here is a LED setup I made which with each one of those LEDs putting out 40 lumens, is not bright enough to match stock...
Back to your question, if you're hoping to find a bolt in replacement to make them brighter, you're not going to find one that is easy. Check out HIDPlanet.com if you want info on lighting, I am a mod there.
Old Mar 26, 2007 | 04:01 AM
ORIGINAL: Ocelaris
Hey Ocelaris, where did you get those SMD LEDs?
Old Mar 27, 2007 | 12:06 AM
Ocelaris's Avatar
I got them from ELED.com
http://www.eled.com/category.asp?cat...SMD+LED&Page=1
But unfortunately they require massive heatsinking otherwise they will fry themselves, you have to heatsink the cathode side really well... check out this thread I made on them...
http://www.hidplanet.com/forums/viewtopic.php?t=26376
Quite a bit of work, not for the faint of heart... Constant Current Regulator driving them, copper slugs for attachment to the aluminum heatsink + fan...
w116tjb
Aug 15, 2012 09:05 AM
Uniqsol
May 22, 2009 10:18 PM
rd05f4
Mar 17, 2008 12:58 PM
schizcat
Feb 16, 2007 03:21 PM
Eric76
Jul 29, 2006 11:00 PM
