Help! Bike Accelerates Wierd
Old May 30, 2013 | 08:44 PM
R3define's Avatar
Default Help! Bike Accelerates Wierd
Well, this is my first post in the 600rr world. As of yesterday I bought an 03 600rr. It has quite a few good mods already as well as only having 7000 miles. Anyways, I was told that it has a Powercommander. He said it was under the seat and the seat was bolted down and I didn't have a wrench to check.
Long story short, I can't find the PC anywhere.
So my problem is that when accelerating it accelerates in increments of about 2k RPM's. Kinda chugging. Also, when going a constant speed it just sits there and bounces up and down.
Can I just buy a PC and tune it with that or do you guys think I might have a worse problem? Really hoping that that's all I need to do.
One other note, the chain is extremely loose. It still seems to spin fine but would this be a cause of my goofy acceleration?
I'm pretty ticked off at this point as I was blatantly lied to about it.
Any help is greatly appreciated! Thanks!
Old Jun 1, 2013 | 11:28 AM
FOGeologist's Avatar
Senior Member and ROTM March 2014
Wait, you didn't test ride before you bought?
Old Jun 1, 2013 | 07:20 PM
R3define's Avatar
I did. I was just told that the pc needed to be remapped. Obviously should have asked a few more questions. But that's the past and I own it now so I'm trying to figure this out. Lol.
Old Jun 1, 2013 | 08:42 PM
CorruptFile's Avatar
June 2013 ROTM
Start by fixing what you know is wrong. Chain tensioned/replaced if needed.
Old Jun 1, 2013 | 10:47 PM
Bryce Swartzwelder's Avatar
Default Power commander
If indeed this bike has a power commander, it will connect between the bikes ecu (computer) and harness. If the ecu has a y harness, simply disconnect it and plug your harness into the stock ecu. If not I am sure someone around here can help.
Old Jun 4, 2013 | 07:20 AM
R3define's Avatar
It definitely needs to be replaced, as well as the sprockets. So I have a chain and sprocket set on the way. Should be here this afternoon.
Old Jun 5, 2013 | 07:01 AM
R3define's Avatar
Update! After replacing my chain and sprockets she runs like a dream! No chugging or anything!
Old Jun 5, 2013 | 08:37 AM
June 2013 ROTM
Good to hear. Always start with the simple things.
Adrjunkie
Sep 19, 2008 08:27 AM
95camaro01f4i
Apr 30, 2007 07:21 PM
hopkinslax12
Feb 8, 2007 07:58 PM
2003F4iDude
Nov 25, 2006 10:45 PM
sm0ke5150
Aug 22, 2006 05:34 PM
