Help! Bike Accelerates Wierd
Well, this is my first post in the 600rr world. As of yesterday I bought an 03 600rr. It has quite a few good mods already as well as only having 7000 miles. Anyways, I was told that it has a Powercommander. He said it was under the seat and the seat was bolted down and I didn't have a wrench to check.
Long story short, I can't find the PC anywhere. So my problem is that when accelerating it accelerates in increments of about 2k RPM's. Kinda chugging. Also, when going a constant speed it just sits there and bounces up and down. Can I just buy a PC and tune it with that or do you guys think I might have a worse problem? Really hoping that that's all I need to do. One other note, the chain is extremely loose. It still seems to spin fine but would this be a cause of my goofy acceleration? I'm pretty ticked off at this point as I was blatantly lied to about it. Any help is greatly appreciated! Thanks! |
Wait, you didn't test ride before you bought?
Originally Posted by FOGeologist
(Post 1235360)
http://upload.wikimedia.org/wikipedi...0/Facepalm.gif
Start by fixing what you know is wrong. Chain tensioned/replaced if needed. |
Power commander
If indeed this bike has a power commander, it will connect between the bikes ecu (computer) and harness. If the ecu has a y harness, simply disconnect it and plug your harness into the stock ecu. If not I am sure someone around here can help.
Originally Posted by CorruptFile
(Post 1235423)
Update! After replacing my chain and sprockets she runs like a dream! No chugging or anything!
Good to hear. Always start with the simple things.
