Bike sounds wierd
Hey guys, im having a wierd problem.
A few weeks ago i noticed the bike would kind of rev wierd when at high rpm and low gear. like would move up and down slightly. best way i could describe it is "wur wur wur wur" as opposed to "wuuurrrrrr" hahaha.
I did get the tire change about a month ago, and i didn't remember it happening before that... could it be unbalanced? or any other problem witht he bike? i can deal with it, but its just kind of annoying.
Not really. No vibration that I can really tell. Shimmy? im not sure what that means... Just what I described. I've heard there might be a flat spot on the tire?
I don't think it's from the engine, because when I rev it stays constant, but only when im moving will in move up and down mabye 200 rpms. I can see the needle move. And it seems to go away at higher speeds.
What tire did you get changed, both? If it is the rear try doing a nice burnout to get that flat spot out of it and to get the oil that comes on new tires off. If its the front, Im not sure.goodluck
95camaro01f4i
Apr 30, 2007 07:21 PM
