Wierd noise????
Old Sep 17, 2008 | 09:40 PM
Adrjunkie's Avatar
Default Wierd noise????
I have a question about my 01' F4i....The last two times I put gas in my bike, it started sounding like a dirtbike after I get on it. I dont know if I am filling the tank up too high, or if that could even cause it to do that. The last time I thought I got bad gas so I drained the entire tank and put about a half tank of new gas in it and it didnt do it. But I just filled it tonight on the way home from work, at a different station,and as soon as I left the station it started doing it again. I also just recently had a tune up. So I dont know if it was maybe something with that..Please help.....Thanks in advance.
Old Sep 17, 2008 | 11:23 PM
drdrewdown's Avatar
Default RE: Wierd noise????
more info if you want real answers..
i would assume u got more bad gas..
what octane are you filling up with? are you only filling up in the hood?
by the way what city do you live in so i know never to fill up there?
Old Sep 18, 2008 | 12:14 AM
Tahoe SC's Avatar
what do you mean by dirt bike?
if you got bad gas sometimes it's not enough to drain the tank. you may have to replace the fuel filter...which is inside the tank...muhhahhahha....pita to get to.
Old Sep 18, 2008 | 02:45 AM
Adrjunkie's Avatar
I went to the same station tonight as I went to the last time I added gas and it was fine. But the two times it did it, I completly filled it up. It only does it when its completly full. And I only fill up with High Grade...And by dirtbike I mean instead of that clean exhaust sound I usually have from my Two Bros exhaust, it sounds like a 250 dirtbike, its like a gargle sound.
Old Sep 18, 2008 | 12:37 PM
ampfp's Avatar
put seafoam and see if that smoothens it out.
Old Sep 18, 2008 | 10:04 PM
Adrjunkie's Avatar
seafoam?????
Old Sep 19, 2008 | 12:25 AM
LaughingMan600F4i's Avatar
I Have A 06 And I Fill It Up To The Top With High Grade And Mine Sounds The Same But Have You Tried Not Filling It To The Vary Top Like 90% Full Or So?
Old Sep 19, 2008 | 12:34 AM
jdschmidt's Avatar
Seafoam is one of those products that works very well and sells because it works. As you put miles on combustion engines they build up carbon deposits inside that will affect performance. Carburetors can become gummed up from sitting with gas in them. While SeaFoam is a grreat gas treatment product and helps prevent problems with these things...it also works well to clean the internals of an engine and carburetors which keeps your engine running in top shape. You can buy it at Napa Auto Parts stores.
Old Sep 19, 2008 | 08:27 AM
That_Guy's Avatar
I'd say get a new fuel filter, some engine cleaner that works by putting in the gas tank and letting it run through with the gas, and stopping at a gas station like BP or Shell, thats about the best top quality gas your going to get. If all that doesn't work then maybe that bad gas did a number on the engine even though it sounds unlikely... but it could of just absolutely gummed up the fuel injectors or valves. Experiment is all i can say at this point.
titans746
Jun 14, 2013 02:56 AM
silkyjohhson
Sep 8, 2012 10:44 AM
focus01
Oct 2, 2008 08:46 PM
fiveoh
Feb 9, 2008 04:52 PM
BW
Aug 5, 2007 01:33 PM
