Dies in gear
Old Nov 22, 2012 | 01:28 PM
Blackbeauty16's Avatar
Default Dies in gear
I have my 1994 CBR 600 streetfighter running now. It idles now and has a new battery and key ignition. I have spark. The clutches engage and disengage. when i go to shift it down into first its just dies... no jerking or motion. I thought it was the kickstand sensor so I bypassed it like it said to on another forum and still no luck.. I feel like its just electrical. What are all the possible sensors that can kill it when I take it out of neutral? Or has anyone else had this problem?
Old Nov 26, 2012 | 06:49 AM
rd91si's Avatar
I think there is one on the clutch lever.
Old Nov 26, 2012 | 05:54 PM
MadHattr059's Avatar
Check the switch on the left (clutch) lever. If it's bad, it might kill the engine.
Same as the kick-stand, pull the two wires and short between them.
I would still trace the wires going to/from the kick-stand sensor.
If it's the harness that's damaged, a simple by-pass at the switch,
won't eliminate the problem.
Ern
Old Nov 27, 2012 | 01:43 PM
so how and where can i bypass the clutch sensor?
Old Nov 27, 2012 | 06:04 PM
Ern
Old Nov 28, 2012 | 02:52 PM
Thanks.. sorry I over looked that Im going to check it out tonight or tomorrow
Old Nov 28, 2012 | 04:07 PM
estate4life's Avatar
February 2012 ROTM
Kickstand switch or clutch lever sensor...no need to bypass if really not necessary. On the left handle, pull the clutch lever in and hold it. Look inside the perch that holds the clutch cable. There is a pin inside that springs up when you pull the lever. When lever is release, lever presses the pin down. The pin switch can get sticky and stays down eventhough you pull on the clutch. Sometimes a good cleaning can fix problem but if switch is bad, replace it cost about $25.
You can test it by removing the 2 wires inlet on the perch and touch them.
Old Nov 28, 2012 | 06:30 PM
You guys are great!!! It was the clutch sensor! easy fix...just bypassed for now
greddy_1700
May 15, 2011 11:55 PM
SilverF3
Jul 28, 2008 07:06 PM
ReSpEcT
Sep 8, 2007 03:16 PM
bwhittington00
Sep 4, 2007 05:43 PM
NWOleman
Nov 5, 2006 01:29 PM
