Shift into gear and Dies HELP
Old Jul 28, 2008 | 02:48 PM
SilverF3's Avatar
Default Shift into gear and Dies HELP
I shift into gear and bike shuts off and when my kick stand is down the light is not light? help plz
Old Jul 28, 2008 | 03:09 PM
SilverF3's Avatar
Default RE: Shift into gear and Dies HELP
can i jump the two wires on the side stand or is this not the problem. thanks for your time.
Old Jul 28, 2008 | 03:45 PM
SilverF3's Avatar
any ideas would help alot thanks pplz
Old Jul 28, 2008 | 05:19 PM
pacemaker's Avatar
Not sure wot your saying, but putting the bike in gear with the side stand down, will cut the motor, that's normal. If its cutting out with the stand up, then you have a faulty side stand switch.
Old Jul 28, 2008 | 05:22 PM
lonewolfcbr's Avatar
what pacemaker said
Old Jul 28, 2008 | 05:24 PM
SilverF3's Avatar
ok i jump the sidestand now when i pull my clutch in the sidestand light comes on , when i first got the bike the starter relay was all hooked up backwards but the sidestand and clutch all worked and i would have to take it off the stand and hold teh clutch in to get it to start now i just push the button and it starts. help i want to go RIDE THIS BITCH ALREADY> MAN ITS BEEN A LONG TIME JUST GOT A NEW TAG TODAY> HELP PLZZZZZZZZZZZZZZZZZZZZZZ others ARE waiting for me as i type.
Old Jul 28, 2008 | 05:57 PM
you got yourself a little wiring issue there i see...is it still cutting off when in gear w/sidestand up
Old Jul 28, 2008 | 06:09 PM
SilverF3's Avatar
yes when i did get it to go in gear and ride it it would cut off like the sidestand fell down then cut bake on.
Old Jul 28, 2008 | 07:06 PM
SilverF3's Avatar
ok i hooked it back backwards and no power or blow a fuse .
Blackbeauty16
Nov 28, 2012 06:30 PM
Trent Dog
Jul 9, 2012 06:32 PM
ReSpEcT
Sep 8, 2007 03:16 PM
howudoin73921
Oct 14, 2006 12:56 PM
slopoke05
May 19, 2006 12:20 PM
