clutch cable
Old 01-14-2022, 01:18 PM
jmp's Avatar
jmp
jmp is offline
Default Clutch cable
Up date ordered clutch cable it came but the measurements was slightly wrong outer cable was fine the inner cable was a bit to long as fully adjusted only pulled clutch half way in and there was no other size cables near what i needed in the shop so I got a Alan bolt that fit my leaver and drilled a hole through the middle then cut down one side just like the clutch leaver adjuster on the bike already but the one I made was twice as long so took up the slack so feels good but at the moment to cold 🥶 to take it out but I’m sure it will work fine now thanks again for taking the time to help me out thank you 😊
The following users liked this post:
IDoDirt (01-16-2022)
Old 01-14-2022, 01:45 PM
Fantastic jmp, there's home grown ingenuity for you.
Thanks for letting us know how you got on and fingers crossed when the weather picks up that it operates correctly.
phiah
02-21-2013 07:00 AM
cuetip
12-28-2011 07:13 PM
rray12288
08-11-2008 12:04 PM
Todd84
06-03-2008 10:43 AM
Mikes03954RR
07-30-2007 03:20 PM
Quick Reply: clutch cable
