clutch cable
Old Dec 24, 2011 | 01:27 PM
cuetip's Avatar
Default clutch cable
ok well my clutch is really hard to pull and there is no kinks in it, and its the stock cable i was wondering if i was to get a new clutch cable would it help and make it easier to pull?? or with an easy pull to go with the new clutch cable
Old Dec 24, 2011 | 01:31 PM
gotcbr's Avatar
Check adjustment & lubrication. Remember, your F4's cable is 10+ yrs old. May be time for a new one.
Old Dec 24, 2011 | 02:45 PM
cuetip's Avatar
ok will get a new one after christmas and a new gas cap
Old Dec 25, 2011 | 03:11 AM
zaqwert6's Avatar
Nov 2011 ROTM
Unhook the cable at the clutch side and see if the issue is with the cable or if it moves freely. If the cable itself is not frayed or the outer sleeve worn through you might get away with running some simple lubrication down the cable.
Old Dec 25, 2011 | 09:17 PM
adrenalnjunky's Avatar
since you also posted a thred that your throttle cbles have become stiff after you moved everythin gto a new set of dirt-style bars - I'm wondering if your cables don't have enough slack to operate properly.
Old Dec 28, 2011 | 07:13 PM
cuetip's Avatar
well these are my second clipons lol, and the first pair all i had to do was adjust the cable, but ive ordered at new clutch cable, but once i lubed up the cable it helped a little bit not alot
Zandaloo
Aug 22, 2013 03:26 PM
fbpsb82
Jan 30, 2010 02:23 PM
lsybert
Jun 25, 2009 11:07 AM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
