Suspension Set Up
Old Jul 2, 2020 | 03:23 AM
stevie1958's Avatar
Default Suspension Set Up
I got my cbr600 f2 (93), does anyone know what position the mono shock should be set at i am 144lbs, the shock has numbers on it but I'm not sure what it should be set at,thank you.
Old Jul 2, 2020 | 06:39 AM
Doc Samson's Avatar
Lighter weight = lower number. At your weight, I'd guess you'd want to start at a 2 or 3, but to be precise, you want someone to measure how much the suspension sags when you put your weight on it and adjust as necessary. Dave Moss is pretty much the GOAT when it comes to suspension setting -
Old Jul 2, 2020 | 09:28 AM
stevie1958's Avatar
Lighter weight = lower number. At your weight, I'd guess you'd want to start at a 2 or 3, but to be precise, you want someone to measure how much the suspension sags when you put your weight on it and adjust as necessary. Dave Moss is pretty much the GOAT when it comes to suspension setting - https://www.youtube.com/watch?v=3FeZJRiAXRk
thanks for that, I will get an adjustment tool and try it,
Old Jul 3, 2020 | 11:40 AM
stevie1958's Avatar
Well i got c spanner to adjust the rear shock,however I can not get it move at all,used wd40 tried using a drift with gentle taps with a hammer but no joy,is there a locking nut somewhere,
Old Jul 4, 2020 | 06:38 AM
Doc Samson's Avatar
Check this thread for some info and suggestions - https://cbrforum.com/forum/f4i-main-...-101345/page2/
I stood on two stools and hauled up on the grab bar in back while the wife turned it for me! It does not turn easily...
Old Aug 15, 2020 | 05:05 PM
fword's Avatar
Great video posted already. Here is a calculator which may also be of use:
Motorcycle Suspension Sag Calculator | Set your sage for any sportbike, dirtbike or cruiser
daddywilson
Mar 23, 2012 12:41 AM
pissdew
Aug 4, 2011 11:27 PM
oldschoolsdime92
Jun 17, 2009 07:04 PM
eyesky2002
Jan 14, 2009 08:11 PM
WACBR
Nov 30, 2008 04:18 AM
