suspension sag
Old Jun 10, 2009 | 05:19 PM
oldschoolsdime92's Avatar
Default suspension sag
Im about 190-200 lbs, depending what ive eaten that day, my suspension is set all the way soft. I was wondering what kind of settings I would be looking at to set my sag and stiffen things up a bit? I feel I can get more out of the corners if i stiffen it up a smidge thanks in advance!
Old Jun 10, 2009 | 05:38 PM
Great article on setting the sag on your bike.
http://www.motorcyclistonline.com/ho...tup/index.html
Old Jun 10, 2009 | 10:24 PM
thank you very much sir!
Old Jun 11, 2009 | 11:46 AM
so now for the dumb question. To set the sag, which adjustment am I adjusting? The two little spots on top of the fork legs? And on the rear there are two adjustments. one on the resivour and one on the shock itself.
Old Jun 11, 2009 | 03:49 PM
land_warrior.rus's Avatar
FORKS: inside adjuster ( adjusted with a screwdriver) is for dumping, outside adjuster (adjusted with a spaner) is for sag/preload adjustment.
SHOCK: adjusters on the resivour for adjusting dumping, adjuster on the shock itself (adjusted with a screwdriver) is for compression, and there is one more adjustment - sag/preload adjustment (adjusted using C spaner, right under the spring itself).
Preload or springs is responsible for SAG. So to set sag at the front (forks) you will have to adjust spring preload in each fork, to stiffen - turn the outside fork adjuster clockwise and vice versa.
To adjust sag at the rear shock you have to adjust spring preload, to stiffen - turn spring preload adjuster using C spaner clockwise (7 is the max).
Hope it helps.
Old Jun 17, 2009 | 07:04 PM
Bo Major's Avatar
Excellent video here:
http://www.onthethrottle.com/content/view/73/40/
You may need to scroll down the page just a bit to see the video.
doc6335
Jul 19, 2012 09:05 PM
thatdarkknight
Sep 19, 2006 11:06 PM
PERT1905
Sep 19, 2006 12:14 AM
exup547
Sep 14, 2006 08:10 PM
exup547
Sep 14, 2006 04:40 PM
