Honda Cbr 600RR 2008 Blowing Fuses
Old 04-28-2019, 01:05 AM
Reck Reck Aces Guerrero's Avatar
Default Honda Cbr 600RR 2008 Blowing Fuses
Quck questions for you guys. I have a 08 cbr 600rr. I dont have anything aftermarket , so no LEDs or any of that, running stock. But for some reason lately i been replacing my cluster fuse often. Was wondering if any of you guys had a fix for this. Everything works like my front light and my blinkers and my tail light when i hit the brakes the light on but when not compressing the brakes there isn't any rear light. If you have a fix please tell me !! thanks in advanced.
Old 04-28-2019, 01:27 AM
CaBaRet's Avatar
Hi , when does it fuse, is it when you use the foot pedal or the brake lever , or both
Old 04-28-2019, 02:02 AM
you know what i really dont know. ima see when it blows again and i will get back to you.
Old 04-28-2019, 02:14 AM
CaBaRet's Avatar
You could probably try that when its on the paddock stand
Old 04-28-2019, 02:35 AM
yeah so i went ahead and replaced the Fuse. and let it Idle for about 10 mins and turned on my Headlights and high beams and still no blown fuse. also rode it around for a bit and still nothing everything seems to work. I think when its hotter outside cuz i live in AZ. i think it blows when it hot but why tho?
Old 04-28-2019, 02:42 AM
CaBaRet's Avatar
Yeh , although I love Honda's the wiring and connectors can be rubbish, heat produces resistance in connectors and wiring , can only suggest cleaning connectors with this
https://www.ebay.co.uk/itm/Electrica...MAAOSwEeBcsho5
Dont use the ordinary WD40
Old 05-03-2019, 11:11 PM
yeah i made sure all my connectors are clean i will go ahead and buy that asap but i noticed that when i try to Wheelie it blew when i pulled the clutch and rev then it blew.
Old 05-03-2019, 11:46 PM
CaBaRet's Avatar
Maybe its a shorting wire to earth, but you will have to check the wiring for that, you could start by taking out the fuses that dont need to run the bike,see if it still happens ,then replace the fuses one by one and test each time till it blows again, which fuses blows normally
ttemby
09-13-2012 10:01 AM
enigmaxxxx
10-05-2008 07:38 AM
o0quiksilver0o
04-18-2008 08:41 AM
DeeQcbr
11-02-2007 03:48 PM
ox.
05-26-2006 12:13 AM
Quick Reply: Honda Cbr 600RR 2008 Blowing Fuses
