Brake light fuse/ blinker fuse
Old May 25, 2006 | 03:11 AM
ox.'s Avatar
ox.
Default Brake light fuse/ blinker fuse
I keep blowing the brake light/ blinker fuse. any ideas? I have a tail light integrator that has been in the bike for about 3 months with no problems. could it be anythign else, i have checked all grounds and all wireing seems to look ok. If i replace the fuse it works fine in the garage but when i return from a ride they are out again. Please help
Old May 25, 2006 | 05:01 AM
shraz's Avatar
Default RE: Brake light fuse/ blinker fuse
maybe the bulb
Old May 25, 2006 | 10:46 PM
DThompson's Avatar
Somethings gotta be touchin somewhere. I dont know exactly but it wouldnt work in the garage and be blown when you come back unless something is bouncing into something else or something of that sort. Check to make sure all your wires are away from eachother and that no power wires are touching the frame or close to it.
Old May 25, 2006 | 11:57 PM
ox.'s Avatar
ox.
I think i found it. the shock was pinching the wires while the suspension was cycling. Everying was moved and i looks like it will be ok. I will keep ou updated!
Old May 26, 2006 | 12:13 AM
f4istunna's Avatar
that'll do it your wire was probably grounding out
hmm
Feb 12, 2015 02:18 PM
stinkpalm
May 4, 2010 01:28 PM
T
Jan 1, 2008 10:27 AM
Rampage
Apr 1, 2007 11:11 PM
Spike
Jul 6, 2006 08:47 PM
