Help, tail light install gone wrong!
Old Apr 16, 2008 | 11:09 PM
o0quiksilver0o's Avatar
Default Help, tail light install gone wrong!
Well I decided I was going to put my integrated tail light in today,well I ****ed up somewhere.
I plugged the tail light in and worked good. Next, I plugged the turn signals in and blew somthing. The odometer wouldn't work and the tail light and turn signals won't work now.
I looked at the little fuse box under the seat and there were only 4 10amp fuses.. None of them were blown. I swapped back out to stock lights and still won't work. I had to of blown a fuse but don't know where to find it. Can you guys shed any light on this?
While I am on the topic what the hell do you do about wiring this thing up. I understand the tail light/brake light/running light but for the turn signals there is only 1 wire for the left/right. What the hell do I hook that to? I hooked it up to the positive side and it got me where I am now.
I'm not the most electrical inclined person but I can manage most of the time :P
Old Apr 17, 2008 | 06:26 AM
jessej05's Avatar
Default RE: Help, tail light install gone wrong!
well i looked in my manual and theres a main fuse 30a on the right side of the battery. it says its located on the starter motor magnetic switch under the seat. it also says make sure your key is in the OFF position before replacing fuses. maybe you had it on in the first place to cause it to blow? hope this helps
Old Apr 17, 2008 | 07:38 AM
I checked the 30 amp fuse and no luck.. Maybe I fried one of my flush mounts :\ and thats why its not working but I don't know.
Old Apr 17, 2008 | 09:25 AM
jessej05's Avatar
ill do some more searchin see if i can find anything
Old Apr 17, 2008 | 10:39 AM
cbr600f4rocks's Avatar
I had the same problem when i installed my tail light. You blew a fuse, i used a tool (dont know the name of it) looks like a screw driver that has light bulb in the handle and pluged it in and found out which one works the turn signal and used that port, if you use the other one it will blow the fuse.
Old Apr 17, 2008 | 09:49 PM
All the fuses I've checked are good so far.. The top two spots for fuses on the little fuse box with 10amp fuses are missing.
My buddy told me about a 20 amp fuse thats behind the front fairing? Could this be it, I havn't had a chance to go check it out yet.
Old Apr 18, 2008 | 08:41 AM
i have no idea about the one behind the fairing, all i know is when i done it i blew a fuse in the fuse box right above the battery, and i think it was labeled on top of the box as horn/something else. it is a 10 amp fuse i blew, i just went out to check on my bike, sorry that is all i know.
403F4
Jul 15, 2015 05:53 PM
f4i guy
Apr 18, 2012 06:26 PM
compulady5
How-To: Mechanical
Mar 2, 2008 07:39 PM
eee4666
Aug 19, 2007 08:49 PM
plasteredbassist
Jun 1, 2006 10:16 PM
