Honda Cbr 600RR 2008 Blowing Fuses
Quck questions for you guys. I have a 08 cbr 600rr. I dont have anything aftermarket , so no LEDs or any of that, running stock. But for some reason lately i been replacing my cluster fuse often. Was wondering if any of you guys had a fix for this. Everything works like my front light and my blinkers and my tail light when i hit the brakes the light on but when not compressing the brakes there isn't any rear light. If you have a fix please tell me !! thanks in advanced.
yeah so i went ahead and replaced the Fuse. and let it Idle for about 10 mins and turned on my Headlights and high beams and still no blown fuse. also rode it around for a bit and still nothing everything seems to work. I think when its hotter outside cuz i live in AZ. i think it blows when it hot but why tho?
Yeh , although I love Honda's the wiring and connectors can be rubbish, heat produces resistance in connectors and wiring , can only suggest cleaning connectors with this
https://www.ebay.co.uk/itm/Electrica...MAAOSwEeBcsho5
Dont use the ordinary WD40
Maybe its a shorting wire to earth, but you will have to check the wiring for that, you could start by taking out the fuses that dont need to run the bike,see if it still happens ,then replace the fuses one by one and test each time till it blows again, which fuses blows normally
