How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Integrated Tail ....Make one yourself for $12
Old Jan 13, 2010 | 10:09 PM
  #61
mr93t's Avatar
Does anyone have a write up with more photos for "the rest of us"
Just not sure how everything should be soldered up.
Old Nov 22, 2013 | 08:59 PM
  #62
AntP1987's Avatar
i know this is a long shot here, and sorry to bring up such an ancient thread. But I hope someone can help. This is an awesome write up btw, i just finished this on my 06 F4i. Almost everything worked flawlessly, except, I cant get my right running light to stay on. signals, brakes, work fine. but only the left side will stay lit up when not applying the brakes (the running light). Does anyone know what could possibly going on here? I've checked for shorts, i've tried another relay, i've redone my work about 3/4 times, but cant get it.
Old Apr 17, 2014 | 11:30 AM
  #63
MattR302's Avatar
As much as I like DIY soldering projects, here's how to do it with a 5-wire to 4-wire trailer converter
Rear Turn Signal Integration How-To (Trailer Kit Conversion) @ ::[ SportbikeGuy.com ]:: - check the PDF on there for wiring instructions
I tried this on my old EX500, but didn't keep it. The left bulb lit up a lot of the right side of the housing when flashing, and vice-versa. In my opinion, you should make some kind of divider to separate the two bulbs inside the lens, maybe a piece of aluminum sheet metal cut to fit, siliconed in place. This would help better separate the left and right side.
__Z__
Dec 5, 2009 09:39 AM
tds94probe
Jan 28, 2008 05:38 PM
Terry954rr
Nov 26, 2007 08:38 PM
sj2494
May 2, 2006 06:36 PM
vipercwf
Mar 31, 2006 10:14 PM
