How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Convert 2 wire signals to 3 Wire Inputs
Old Feb 10, 2011 | 01:28 AM
  #91
edcbr's Avatar
I'm looking online for a variable load flasher relay and was wondering how many pins. I've seen some with 3 or more. Thanks for the info.
Old Feb 20, 2011 | 10:44 PM
  #92
edcbr's Avatar
Great right up. Just finished the conversion to integrated mirrors and it works great.
Thanks again.
Old Feb 21, 2011 | 01:52 PM
  #93
DagonRais's Avatar
Awesome write up I'll have to try it sometime.
Old Feb 21, 2011 | 07:20 PM
  #94
scorpionvmu's Avatar
2011 Ride of the Year
what size diode do you guys used????????
never mind....its right at the beginning, i must off missed it. sorry.
Old Feb 22, 2011 | 05:49 PM
  #95
w108srl's Avatar
Default lights are on.
i just completed one side and my blinker stays on like a running light.
it will blink (a bit too fast but i can try to fix that.)
surely it doesn't stay on always like a running light???
I believe i followed everything correctly...
any suggestions?
wow I feel silly,
i really just wanted to know what the proper way to hook up 2 wires to 3 wire lights.... i get it now!!!
i want to make my (future)audi lights do the same thing so blindly following payed off!
Old Feb 22, 2011 | 05:55 PM
  #96
redzintimidator's Avatar
So ah... You dont want a running light then? You do know that is the whole point of this conversion, right?
Old Feb 23, 2011 | 06:03 PM
  #97
here i did the conversion and it worked perfect.
here it is
http://www.youtube.com/watch?v=EvUVCmxk9S8
its easy to do. it cost me $22 for the lights and $2 for the diodes.
Old Aug 9, 2011 | 05:23 PM
  #98
Duelnsword's Avatar
Registered Users
Exclamation So now what?
I followed the guide with diodes 1N4001 from Radioshack, and it does indeed turn my Hotbodies flushmounts into both running lights and blinkers. But when I use the turn signal, both left and right indicators on the gauge panel flash. When I apply brake, the lights turn off, AND to top it all off, the rear doesn't blink either. In the rear, I have standard bulbs and I do have the hotbodies blinker box, which speeds up the blinkers when brake is pressed. What can I do?
Old Aug 30, 2011 | 09:24 PM
  #99
Trey929RR's Avatar
Default Horn works
here it is
1998 honda CBR600F3/SJR - YouTube
:42
Old Sep 5, 2011 | 10:24 PM
  #100
0949er's Avatar
dude you are the man!
I am in school right now studding electrical engineering and had a blast doing this fix haha!
Just curious, what is the difference in the blue and blue-white-stripe wire? Like what exactly are they for? My flush mount came with two wires which are your normal + and - leads. So I figured that the harness (the two blue wires) would be +12 and ground (since the guy selling said it would fit my bike). When I hooked up the lights this way, they stayed on all the time and would turn off when the blinker was selected. I did see the green ground wire on a separate wire, but at this point I didn't want to cut up any of the wires (on either the bike side or the blinker side) so I got online and found this post!
also, why do you need diodes on the lines? just curious! thanks man!
