sticky throttle
Old Dec 19, 2010 | 11:34 AM
Xander F4i's Avatar
Default sticky throttle
I changed my throttle tube last night once I had everything back together it seems a little sticky on the return...though nothing seems to be binding anywhere.
Any ideas on where to check?
Old Dec 19, 2010 | 04:38 PM
tanrush's Avatar
Take it back apart, oil the cable with wd40 so that it has an opportunity to leak down the wires. Inspect the white plastic area and make sure that nothing is binding or sticking out. Look for burrs, anything not smooth. Make sure your cable wires are actually in there groove as they should be. Shoot some wd40 in there as well (inside the housing where the 2 cables connect). Close it back together with your fingers and check for sticking, if it is smooth then put the screws back in it and it should not bind now. If it is not snapping back when you let go then you still have a binding/mechanical problem.
Old Dec 19, 2010 | 07:47 PM
Xander F4i's Avatar
Alright thanks...I'll double check it as soon as I can
Old Dec 19, 2010 | 08:15 PM
Xander F4i's Avatar
Should the clip on be lubricated? If so, what should I use?
Old Dec 20, 2010 | 09:40 AM
adrenalnjunky's Avatar
If you have your cables disconnected and the throttle tube turns freely, it should be fine.
I had a similar problem with my F2 when I bought it - but it was due to the old cables being worn and dirty. Bought new cables and installed. they worked fine with the airbox off the bike, but with it on, the return picked up some drag again.
After about 3 removals of the airbox, I finally found that I needed to re-route one of the cables slightly differently and all was better. apparently something was pushing a cable slightly into a position where the cable just wasn't happy moving freely through.
Old Dec 20, 2010 | 01:56 PM
TimBucTwo's Avatar
Also make sure that there is some slack in the cables. Without slack they will not be free to return.
Old Dec 20, 2010 | 09:00 PM
Sprock's Avatar
+1 on having the cable loose , no tight spots or she'll bind.
Old Dec 26, 2010 | 10:19 PM
Xander F4i's Avatar
I'm pretty sure I got my issue resolved by changing the lubrication, as I now get an audible snap when I let go of the throttle. Thanks to all who offered ideas on my possible issue. Now I just need good enough weather to take the new throttle for a test drive.
Mwall
Aug 28, 2008 04:13 PM
toeknee1986
May 24, 2008 09:52 PM
cbrvroom
Apr 29, 2008 04:45 PM
kpshogry
Dec 4, 2007 09:30 AM
Cutlassjim
Jun 19, 2006 10:35 PM
