Sticky Throttle
Old May 22, 2008 | 11:52 AM
toeknee1986's Avatar
Default Sticky Throttle
rookie here! I got what seems to be a sticky throttle.... when I leave go of the throttle it stays open for about a seconda and a half before it closes! Jesus..when it first started to do it...I had to pull an emergency brake lol. I wasn't close to an accident but still I shat my pants for that second and a half. Anyways I need some tips on what it could be..I'm guessing iether I need lube on the throttle cables? Or worst I need to change the cable? Iethere way I kinda wan to try and fix it myself if I could. So I need a how to guys plz help thx in advance.
I'm sure this post could help out some other newbies.
Old May 22, 2008 | 01:19 PM
Ayres_08's Avatar
Default RE: Sticky Throttle
DO not put oil in ur throttle cable. This will make it better for a lil while but it will get 10x's worse. Oil attracts dirt if u havent noticed that. Buy a new cable. Its very cheap and cant be hard to put on.
Old May 22, 2008 | 02:03 PM
redzintimidator's Avatar
I dont know about the f2's, but in the f3's there are two cables. try to adjust the two cables under the gas tank near the carbs. My guess is the snap back cable isnt adjusted right. You should be good after that adjustment.
Old May 23, 2008 | 07:18 AM
woo545's Avatar
They do make cable lube. That is supposed to be ok to use.
Old May 23, 2008 | 12:52 PM
flashman's Avatar
The cables are in a casing so lubing them would be fine. You can try that, and like was stated already we have 2 cables so it could be adjusted wrong. Check the cables and if you have to replace them it wouldnt be tough just time consuming and a bit of a headache because of the handle. A trick if you have to replace the cables would be to remove the clipon, that way you dont have to try and stretch the cable to reach the handle.
Old May 23, 2008 | 08:10 PM
Ayres_08's Avatar
ORIGINAL: flashman
Lube them and see how long that lasts. Been there done that.
Old May 23, 2008 | 08:57 PM
elmer's Avatar
If that doesn't work check to see if your bar end is pinching your grip on the throttle clip on itself. That was the problem on mine, the bar end was pinching the grip so the throttle was like cruise control.
Old May 24, 2008 | 09:52 PM
spdbump36's Avatar
I had that same problem but someone had wired them in wrong and the place where the return cable is held on the little mount, it got loose and feel off so no back tension.
Mwall
Aug 28, 2008 04:13 PM
cbrvroom
Apr 29, 2008 04:45 PM
ken12
Mar 10, 2008 09:28 AM
kpshogry
Dec 4, 2007 09:30 AM
Cutlassjim
Jun 19, 2006 10:35 PM
