Sticky Throttle
Old Aug 27, 2008 | 10:32 PM
Mwall's Avatar
Default Sticky Throttle
I've had two seperate people tell me my throttle is sticky and I've had once where it stuck at redline for fraction of a second and in rev matching down shifts.
How do I fix this?
Old Aug 27, 2008 | 11:07 PM
travsstuff's Avatar
Default RE: Sticky Throttle
ORIGINAL: Mwall
How do I fix this?
sticky how.....as it the cable / grip area.....if so, they make cable lube, it comes in kits with a tool that ya use, I have never used it, but have heard good things..... if its just getting stuck at redline, check your throttle pos. sensor, located right below the gas tank on the right side, make sure its tight, and didnt come loose or get bumped.....
Old Aug 28, 2008 | 02:50 AM
usetheffours's Avatar
Make sure it not the grip getting in the way. take off the bar end and move the grip around and see if it something simple. hada f3the grip was rubbing the bar end and the throttle cable mount housing and caused it to stick.
Old Aug 28, 2008 | 05:40 AM
MC_spirited's Avatar
It can be the grip rubbing against the control pod or bar end. if that the case you can put some grease on the areas that are rubbing. If it is the cables the lube tool works well. Other than that I odnt know what to say.
Old Aug 28, 2008 | 04:13 PM
WOT's Avatar
WOT
Often your throttle can hang because your cable is bent or twisted. Also try loosening the screws holding your throttle housing to your bar and see if it fixes it.
toeknee1986
May 24, 2008 09:52 PM
cbrvroom
Apr 29, 2008 04:45 PM
ken12
Mar 10, 2008 09:28 AM
kpshogry
Dec 4, 2007 09:30 AM
Cutlassjim
Jun 19, 2006 10:35 PM
