Replacing R/R, Stator, & Battery
Old Apr 24, 2013 | 10:10 AM
DerekClouser's Avatar
Default Replacing R/R, Stator, & Battery
My Bike : 1998 Honda CBR 900RR
Went out last night & hit up some local park twisties and bike started acting real funny - got it home, turned off and went to turn back on immediately and nothing.
Had battery issues, so I went to put on a charge and battery charger gave me an error saying the battery was bad. Did some research online and found out that it was more likely a r/r & stator issue because apparently my bike is known for it. So I decided to just buy a new stator and r/r to replace the OEM parts.
I'm not very mechanical but I'm going to attempt to replace these parts myself (mostly because I want to learn to become self sufficient on my bike) - Anyone have any tips before I do this so I don't mess anything up. I'll be referring to the CBR repair manual but is there any tricks that I should know before heading in such as any specific tools I may need that I may not already have.
Any help would greatly be appreciated.
Old Apr 24, 2013 | 12:33 PM
cc rider's Avatar
So you bought both a stator and a r/r without knowing which one is bad. What about checking to see if they are bad first? I just saw the stator runs $240 and the rr $135. I had my cover off before. The hardest part of this job(not that it is hard) that you are trying to do is getting a good seal when replacing the alternator cover. Make sure you have a new gasket for the cover and apply sealant (I think i used hondabond) where the wire grommet goes into the cover. The rest is screwing/unscrewing. Oh and make sure your screws are torqued correctly- 12nm,9lbft.
Old Apr 24, 2013 | 02:15 PM
The longer I wait on parts, the longer I can't ride... Living in Ohio, you have to take advantage of all riding time you can.
Old Apr 25, 2013 | 09:30 AM
MadHattr059's Avatar
Drain the oil when replacing the stator, as well.
Also, no matter how tempting don't pry around the gasket-seat.
You will damage the mating surfaces and never get a good oil seal afterwards.
Thoroughly remove the old gasket, being careful to not scrape the faces.
It's tough pulling the stator cover, due to the strong permanent magnets fixed to it.
Exercise your patience, not your muscles.
Good luck, Ern
Old Apr 25, 2013 | 10:58 AM
cc rider's Avatar
I didnt drain the oil. You'll only lose a couple drops that are behind the cover. I think mine was on a paddock stand though. Can't remember how I did it. If you have it on the kickstand, you might lose oil. I don't know what kind of angle the bike has to be at for it to start leaking out. It did require a little patience to get off but its not hard. If you do damage the cover , i have an extra one I'll sell you
C2H5OH
Jan 6, 2014 10:58 PM
cbrrrrrrrr
Apr 26, 2010 09:04 PM
bluestanger66
Apr 27, 2007 07:48 PM
Bobinbaghdad
Apr 7, 2007 02:12 AM
pinkcookies26
Nov 12, 2006 03:31 PM
