Not starting properly CBR600F4i
Old Aug 21, 2012 | 07:34 AM
Joey's Avatar
New Member
Default Not starting properly CBR600F4i
I have a 2002 CBR600F4i. I was out of town last weekend and unfortunately the bike was left out and it rained that weekend. Bike started up fine when I got back but later that evening it wouldnt. The bike displays as if my brights are on, but neither of my headlights work. When I hit the fuel switch nothing happens, no noise of any kind. I continued to try and start it but it would not turn over. Battery is fine brake lights and blinkers work and horn. I got it to start but only because the start button was stuck and when I puled it back out to the original position the bike shut off. Any help and ideas would be great. Thanks and ride safe.
Old Aug 21, 2012 | 11:10 AM
Joey's Avatar
New Member
When the bike did start the headlights still did not work
Old Aug 21, 2012 | 02:41 PM
gotcbr's Avatar
The starting switch has been problematic on F4/F4i's. What you described - having to pull out the start button - was what my F4 experienced as well. As you know, the switch cuts power to the headlight during the starting procedure. After start, the light immediately comes on. Sometimes the contacts in the switch get corroded/dirty/etc. Try spraying some WD40 in the switch first. Then, if that doesn't do the trick, open up the switch & clean it. The switch could simply be worn out but more than likely, it will still work w/a cleaning. Give that a try first & see if it helps.
Abergeron
Jun 19, 2013 02:46 PM
Hootie233
Mar 21, 2012 11:30 AM
pl419090
Jun 27, 2011 11:13 AM
Jono7461
Jan 10, 2010 03:24 AM
F4sRule
Mar 16, 2009 11:55 PM
