Endless Chain Question
Old Aug 17, 2012 | 10:41 PM
cschew's Avatar
Default Endless Chain Question
A guy from my local area forum is selling an RK 525 XSO X-Ring 108 links ENDLESS chain.
He says its okay to cut one of the links off and replace it with a master link.
Is it safe/recommended to do this? Or should I avoid this?
RK Drive Chain - BARF - Bay Area Riders Forum
Thanks!
-Collin
Old Aug 18, 2012 | 12:37 AM
boredandstroked's Avatar
Looks new in the bag, which should mean the master link isen't installed yet and the chain isen't a completed loop yet. If its used I wouldn't touch it.
Old Aug 18, 2012 | 10:30 AM
zaqwert6's Avatar
Nov 2011 ROTM
Could be wrong but that sure looks 'continous' in the bag. Guessing its an OEM chain?
But yeah , nothing wrong with cutting into it and putting in a master link.
Old Aug 18, 2012 | 12:12 PM
cschew's Avatar
It's an :endless" chain that comes already linked together without a master link. So I guess I have to cut it and put a master link on because I really don't feel like removing the swingarm to do this!
Old Aug 18, 2012 | 11:46 PM
Weird, chains that use rivit masters are usually reffered to as endless but don't come pre-linked. Don't worry about cutting it and adding a new rivit master it will be just as strong.
Old Aug 19, 2012 | 09:58 AM
daviej's Avatar
Isnt the cbr a 520 chain?
Old Aug 19, 2012 | 01:44 PM
sjona2011's Avatar
If you do get it and plan on installing it yourself, if suggest getting the proper tool to do it, I just replaced my chain and sprockets a few days ago and getting the masterlink in and riveted was a PITA to say the least
Old Aug 20, 2012 | 12:41 PM
zaqwert6's Avatar
Nov 2011 ROTM
Lot of chains ordered as OEM spec'd come that way.
Old Aug 21, 2012 | 02:54 PM
gotcbr's Avatar
Collin,
The F4i does use a 108 link chain.
Have you ever installed a chain? Its not rocket-science but should be done properly. As recommended above, use the proper chain tool to properly install the master-link. The master-link pins need to be flared/staked to proper spec (RK = 5.55-5.85 mm / 0.219-0.230 in).
Here's a great tutorial by Incognito: https://cbrforum.com/forum/how-mecha...et-swap-97641/
Mustafa Jack Tosuncu
Apr 30, 2014 09:27 AM
ncsponger
Aug 18, 2009 11:12 PM
Perranomous
Apr 19, 2009 03:04 AM
Timidfriendly
Jan 18, 2009 12:10 PM
alm70
May 11, 2006 06:08 PM
