noise once i take off???
Guest
Posts: n/a
RE: noise once i take off???
Yer , I go with the guys ..
The chain links if very dry or worn will let out a tick tick noise mate ..
check it right over for wear and lube ...( use good lube too )
If after you check and lube it well , run her down the road a bit to get the lube in properly and if it still ticks.... whack her up on the center stand and spin the wheel to see if the tick is coming from your rear brakes ...
on
1 Post
ORIGINAL: CBRclassic
No **** ?? really... even on tourers ??
I call mine the "old man stand"
ORIGINAL: redzintimidator
center stand?? they dont sell bikes with that nonsense here in the us
...althought it might be handy from time to time
