no power electrically
Old Jul 23, 2007 | 11:22 AM
transman50's Avatar
Default no power electrically
have a 78 cb550k has no power at all completely dead no horn,lights,starter, nothing, i thought main fuse but no found wire in fuse box bad at conecction where power is the red wire i fixed it still nothing im charging battery right now and figure maybe somebody can give me some advice, thanks
Old Jul 23, 2007 | 11:41 AM
MikeInCtown's Avatar
Default RE: no power electrically
Can someone translate this?
Ignition switch controls the power, so I would trace that first and make sure you are getting power to the switch and then from the switch back to any relays. From there it would most likely be a relay problem if one still exists.
Old Jul 23, 2007 | 12:15 PM
transman50's Avatar
thanks for reply mike, i have no manual or info on this bike but there is a relay close to the fuse box not sure what it is tho.
Old Jul 26, 2007 | 02:13 PM
Analog's Avatar
If it were me, and I had a multimeter available, I'd start at the source (battery). Make sure after charging that the voltage is approximately 12.5 - 14 V. Anything less is probably an indicator that the battery is calling it quits.
coolbluedab
Feb 7, 2014 07:13 PM
romanboy
Jan 19, 2013 12:53 AM
__Z__
Jul 14, 2010 10:00 AM
Karmakazi
Sep 29, 2009 09:58 AM
svek
Jul 24, 2008 09:34 PM
