no power electrically
have a 78 cb550k has no power at all completely dead no horn,lights,starter, nothing, i thought main fuse but no found wire in fuse box bad at conecction where power is the red wire i fixed it still nothing im charging battery right now and figure maybe somebody can give me some advice, thanks
RE: no power electrically
thought main fuse but no found wire in fuse box bad at conecction where power is the red wire i fixed it still nothing Ignition switch controls the power, so I would trace that first and make sure you are getting power to the switch and then from the switch back to any relays. From there it would most likely be a relay problem if one still exists. |
thanks for reply mike, i have no manual or info on this bike but there is a relay close to the fuse box not sure what it is tho.
If it were me, and I had a multimeter available, I'd start at the source (battery). Make sure after charging that the voltage is approximately 12.5 - 14 V. Anything less is probably an indicator that the battery is calling it quits.
