Loose chain
Old Jul 18, 2007 | 11:43 AM
Det99cbrf4's Avatar
Default Loose chain
Bought a 99 f4, chain is pretty loud "loose" and i looked down and its still in the "new zone", 11k miles. Is there a writeup on how to adjust this lil guy
Old Jul 18, 2007 | 12:44 PM
Streetdemon's Avatar
I ♥ CBRF
Default RE: Loose chain
Try the search function. Pretty easy though.Just getthe rear tire off the ground with arear stand or jack. Loosen the axle andadjust the tensionbolts on the back of the swing arm.Make sure both sides are even and the chain is straight with the front sprocket. You probably want about 1/2 inch slack(be sure to check it in a few different spots).
If your getting a lot of noise you may also have a dirty chain. I'd clean it up while you got the bike up anyways. Goodluck!
Old Jul 18, 2007 | 01:18 PM
urandaman's Avatar
+1 on the cleaning the chain.. i cleaned mine the other day and lubed it back up and it sounds a bit quiter due to it making its cycles around the sprockets smoother.
Old Jul 18, 2007 | 01:50 PM
MikeInCtown's Avatar
+2 And a clean chain will make the sprockets last longer because the grit isn't wearing away at the metal.
Chain adjustment is about the easiest thing. If you have the tool kit with the bike, it has the necessary wrenches.
Old Jul 18, 2007 | 02:34 PM
voodoochyl's Avatar
Retired Moderator
Ajust and lube your chain every 500 miles. I adjust my chain to about 1" of slack. I would think 1/2" is too tight, but I could be wrong. The axle bolt takes a 22mm socket, the axle nut is a 27mm socket, and the chain adjustors are an 8mm socket. You might check into getting one of those roller deals for the back wheel. They are cheaper than buying a rear stand. Good luck.
Old Jul 18, 2007 | 03:51 PM
tytyguy's Avatar
clean it and lube it up realy good and that should fix the problem!!!!!!
nickp123
Aug 18, 2010 05:01 PM
DarkJuic3b0x
Jun 19, 2010 03:06 AM
nmutroy
Jul 25, 2009 02:04 AM
pr0jktmayhem
Mar 23, 2008 11:38 PM
Det99cbrf4
Jul 18, 2007 06:32 PM
